1 - 13 of 13 Posts
· Registered
No but the custom tunes run so much better than the factory TS tunes!
Sent from AutoGuide.com App
· Registered
Is it safe for me to assume you don't have gauges yet? Get those first, yes its worth it.
Also, a bigger airfilter and free flowing exhaust could/should be done first.
Read all the stickies and save up for a bit.
· Registered
I have an egt gauge and boost pillar gauge. The previous owner had a 4" coming off the turbo that switches to a 5" under the cab and into a muffler. I will check out the the stickies. Thanks a ton!!
· Registered
Custom tunes are much better than the canned from TS. I recently switched to PHP tunes from the canned tunes and I'm much happier with them. I've run four different chips in this truck and so far I like these tunes the best. Stick with the TS style chip so if you want a reburn you won't have trouble finding a good vendor. TW, PHP,Gearhead,Beans all have good reviews so you really can't go wrong with any of them.
· Registered
Gotta a quick newbie ? why do they NOT want you to run the chip setting higher than 50hp while towing? I have a 2000 F350 7.3 CAI, 5 inch from turbo to 6 inch stacks. 6 speed manual
· Registered
Under high power levels, that means a lot of fuel and advanced timing. Yes, there's much more to it, but in a nutshell. Well, you have more weight holding you back when all that power is trying to go forward. Things are strained more than normal.
· Registered
so if I watch my egt's and keep it under 1200 would I be ok that is once I'm up to highway speed. I can always turn it back a notch if I'm going to start climbing a hill. What I mean is could I run say at 75 or 100hp
1 - 13 of 13 Posts
