I have a 2004 ford f350 i did the egr delete on it and after it i started and it ran perfectly fine for a good 20 seconds then it shut off. but it will start right back up everytime. If i start it and rev it up to 1500-2000 RPM's it will stay running. i did the wiggle test and that did nothing. So, I disconnected the ICP sensor this morning and started it and it ran perfectly fine but it started to chug. Once the truck is started and warmed up it runs like a raped ape, but it just seems to only be a issue when the oil is cold. Could i of accidentally got something inside of the IPR valve when my turbo was off? :dunno: it seems like it could be a valid problem, but I wanted to see what you guys thought. Huge Thanks!
lease:
