1 - 20 of 33 Posts
This has happened 3 times in the last week. Twice my truck died when braking, just shut off. The SES light came on but it restarted right away. Another time it died when accelerating, after re-starting from time # 2 above.
I've dug through the other posts similar to this but didn't see many solutions. Ford replaced the CPS on the recall, could this be going bad? Again, I've researched this topic but found no definite answer.
Getting ready for a big trip to Oregon next month and I need to have a safe vehicle to get me there, so any help is appreciated. Thanks in advance.
Oh, not sure if this is related but several months ago it did something similar 3 or 4 times, it would lose power, chug and shudder down the road while surging then clear up. It died once or twice then too, SES came on when it did. It's run like a champ between times.
i think my 01 is doing the same thing your talking about. i crank it and drive it alittle about 10 mins and it goes into a sputtering jerkin and shuts off and the SES comes on. most times i can turn the key off and recrank, SES goes off when i do this. this last time, yesterday, it did it and would not crank back to run but only a approx 2 mins and shut back off. i gave up and got it towed. when i got home and unloaded it and it crank right up and drove around the yard. fuel pump and filter just replaced a few weeks ago thinkin that was the problem. obviously not. any help would be appreciated.
brad
First, try your OBD II reader and see if your getting any codes. If no codes are stored then move to this method (only works if your checking the functionality of your CPS) Crank your engine and watch your tachometer. If your CPS is bad or is going bad your tach will not register cranking rpm's. Also, verify the color of your CPS. Black is bad, grey is better and blue is the best. I have even heard of some getting better performance and fuel economy by using the blue CPS. It can be purchased at your local International dealership and I think the part number for it is as follows; IHC1807339C92. I hope this helps
I've never checked the rpm's when cranking it. I haven't had problems starting my truck, even after it dies...so far at least. I'll check the tach tomorrow AM when I go to work. I'll post again as I find out more.
I don't have a code reader or access to one, unfortnately, unless there's a member in the Missoula MT area that may be able to help out.
Thanks.
when it did it a while back i tried the code reader with no luck. it quit saturday morning and would not crank back. i had it towed back home and soon as unloaded from the roll back it crank right up. monday morning i cranked it and headed to the ford place, only 5 min drive and it quit at about 4 1/2 mins, lol go figure. that was almost the precise time ludwig replied and i recieved it on my blackberry. told me to watch the rpm tach. sure enough, no movement. hitched a ride to the ford place with VIN and found out the recall hadnt be serviced yet and gave me the CPS for free and ran back down and put it on. took every bit of 8 mins to do it. still had the black one on it. but the grey one in it and it crank right up. no problems so far. you were a lifesaver ludwig!
thanks,
brad
not sure what I'm looking for...
When I crank it the RPM's don't seem to register until just a split second before it starts up. Is this normal, or should I see some low RPMs as it cranks?
Hello every one it sounds like I am having the same problem I am driving down the highway and rpm's drop and the truck bucks or kills but it starts back up some times it takes a little while but I can go back on my way. If I am accelerating I can usually keep going but if I am braking or stopped the truck will kill any suggestions
2003 7.3 L - Replaced cps, gray w gray, and engine light still on and engine dies after a couple of minutes - check engine light is on and no OBD II codes - did not remove #9 fuse before install but it looks good - friend suspects fuel pump problem - changed fuel filter 5K mile ago - would like to load camper and travel but can't - thank god i got to the dump and back. any suggestions?
Glad I could help! I have done some research and found that their can be several things to shut your engine down that wont necesarily give a code. All of the values for your oil pressure and fuel pressure need to be manually checked. The factory gauges are not specific enough to get an accurate reading. basically if your oil pressure is low the gauge will read ok, and it will give no codes. but your truck will not start. Also something as little as corroded batter cables can put your truck in a position where it will crank very lively but will not provide enough power to the glow plugs to start. The most interesting clue i have found was while talking with the fellas that maintain commercial truck fleets, one of them told me about two censors that control the injection system (I will find out exactly what they are) these can go bad intermittently, not give codes, and will cause your truck not to start by not initializing the injectors. In the case of my 7.3 I have taken it upon myself to befriend some actual diesel mechanics and not the S**T heads at the stealership. If you know anyone who knows anyone at a semi truck shop it would be worth the time to deliver a 12 pack of cold ones and get them to let you pick there brain's. Its the best tool i ever puirchased.
I replaced the cps and watched the tach it does not move until right before starting and I also tried pulling codes but all I got was error reading I have not put it back on the road yet but I will tommorrow to see if replacing the sensor worked or not and I will let ya'll know if it worked or not
thanks for the help
Nicky
I have been having the same problem in the last few days. It will start and run perfectly then after a couple minutes of driving, it will buck a little, almost like a misfire on a gas engine. It doesn't happen all the time, and when it does, shortly after that it will die. It hasn't died during acceleration yet, only sitting at a stop idle and coasting to a stop or to turn. I really hope I can figure this out.. I don't like not being able to drive my truck!
The Tach moves up while starting, and when it dies it has always started right back up, sometimes while I am still coasting I can just put it in Neutral and start it back up before I stop completely even.
Other vehicle is an F250
sounds like the same problem I had change the camshaft position sensor and that should fix the problem and it is also on a recall from ford it is about $ 30.00's at the auto parts store
Discussion Starter #14
I have a replacement CPS from the recall. Wonder if it's going bad.
What should I see for RPMS when cranking? Nothing registers until just before/as it fires.
that what mine was doing a few weeks ago too. i took the vin to the dealler and said it hadnt had the recall and the when i replaced it, it was the original recalled trouble maker. i havent had any trouble since. CPS ewwhh!
I had a loss of power, never shut off but had to have the intank filter cleaned. Had never heard of it but my buddy a ford tech has had a few come in for the same problem. Not sure if this helps, just thought i would throw it out there!
the tack on mine does not read until right before it starts it ony takes a few minutes to change yhe cps so i would suggest changing it and see if that fixes the problem:icon_ford:
Im in the same boat having mine towed to a ford shop and have them do the recall[ just the recall ]it did not fix it , I towed it home thank god for triple a. it ran the nutz all week and now this morning going up hill it shut off , no light no slow shut down not like it was running out of fuel just off no lights, restarted immediately. I made 70 miles and the truck stalled now its home and ill get a look at it, ill post what I see if anyone wants, maybe we all can fix ours together. ill check with the scanner first ill post the codes maybe we will see a trend.
My 02 7.3 did the same as all of yours 125k on the odometer, it would just flat die. My buddy replaced the CPS twice (he's a certified technician), ran it through the battery of OBDII tests...come to find out it was the Injector Pressure Control Regulator that was acting stupid. It was a $350 fix, but so far, it has acted just fine, and now that the injector pressure it where it should be, it's running like a top again!!!
I was completely unfamiliar with this component, but it is directly underneath the fuel filter. It took a total of 20 minutes to swap out. Just one more thing to be aware of....other than that, no issues so far.
if u still have the same problem i would check the icp sensor
1 - 20 of 33 Posts
