Hey guys, have a 2008 F250 6.4. Locks up when shifting into 3rd. Throwing Codes P1744, P0741, P0772, P2704. It has SCT Tuner full delete with S&B intake and 4 flow pro exhaust. I dropped the pan, magnet had some sludge but nothing to crazy. Ohm tested solenoids, all within spec 4.3-4.4 and EPC/PC-A was at 5.2. Not sure what is going on. Any info would help.
Canned tunes or custom tunes? What hp level? My 6.4 had a shift flare/slam running River City Diesel tuning. Anything other than the tow tune it felt like the trans was going to come apart. Once I changed tunes it went away for the most part. Still never felt 100% shifting into 3rd though, but I changed tunes the moment I started noticing it... I also never ran anything higher than a 100hp tune after that.
I am not a trans guy by any means, hopefully someone can chime in. I think its a safe bet that at the very least, a solenoid is part of the problem. But I doubt its your only issue...
Even if the solenoids checkout electronically, could E be stuck off mechanically?
I also spoke to a few shops and one directed me to possibly the ECM being faulty.
I’m going to put the truck back to complete stock an see what Happens.
I’m having this exact issue, I’m stumped and can’t find anything on this issue. Did you ever get this fixed and if so what was the problem?
