2000 f350 7.3, 85,000 miles, banks stinger system, exhaust brake, trans command. Just replaced the CPS, no change. If im driving it will just die completely and start right back up. water in fuel, SES, and the wait to start light usually come on. SES goes away after i restart, sometimes it stays but not for long. sometimes it wont do it at all, sometimes 10 times in a row. a lot of times it will restart and idle fine but die the second i put it in gear, and others it will start for a second and die instantly. And when it is running it runs like a top.
I know I need to pull codes but untill i do any ideas on what could be causing the problem? I've read a lot about the UVC harness but havent taken the time to pop them off and check. Oh and i just changed the fuel filter and icp sensor because it had oil in the plug.
