1 - 2 of 2 Posts
i have a 2004 6.0 and when i am at any speed crusing 45-75 my truck cuts out. i have tried unhooking the egr and no sucess. when i give it full throttle it just goes no problem but like i mentioned above when giving just enough gas to sustain speed it cuts out :dunno:
Take it in to your local dealer & have the codes run. You may have some random low to high circuit misfire codes set. If so, the FICM circ's will be checked if all good then the FICM will have to be replaced. Done about 6 so far w/ your same concern. Did them on the 03's & 04's.
1 - 2 of 2 Posts
