1 - 1 of 1 Posts
I have a 06 F350 6.0. I use Torque app on my phone to monitor things. No real problems as far as I can tell. Sometimes doesn't start as quick as other times is about the only thing that bothers me. I decided to run a fault check and it came up with these codes. B2900 body, U1900 network, and U2023 network. Seems like I would have to take to dealer or shop with proper test equipment to figure these out. I read where the U1900 could be caused by me pulling my code scanner out of the OBD port while the truck was running but not sure if that was it or not. Wondered if the fact I have EGR delete has something to do with the others. Also maybe switching to different tunes on my SCT might be a reason for the codes. I cleared the codes but in the mean time before I test again for fault code in a few more days;
Has anyone ever come up with these codes on a fault check and should I be concerned with any of them??
1 - 1 of 1 Posts
