1 - 2 of 2 Posts
I have just changed out my HPOP and installed 8 new injectors in my 2004 6.0l. The truck drives good but at about 1250 RPM it has a studer but if you accelerate or decelerate it goes away. But when I do a code check it gives me a P0270 Cylinder #4 injector low circuit. Has any on any ideas I have checked the connection to make sure it was hooked up and also cleared the codes but it continues to pop up. Thanks.
FICM detects an open circuit on #4. Check for a broken wire, bent pin or backed out pin in one of the wwires to #4
1 - 2 of 2 Posts
