Okay fellas how do I take off the trim around the headlite and marker with out tearing apart the whole front end any help:dunno:
you have those two screws on top and then between the radiator support and the battery there are two nuts on studs attached to the back of the marker then they should pull right out after you disconnect lights
The headlight will still be attached to the truck, just the bezel, parking, and corner light will come out
thanks now I know were to look, my grill and trim are factory gray and fading so some black paint is the works ,I was goin' to get some chrome trim pieces but its cheaper to paint them
It is all done thanx csxpaid for the info they painted black I will get some pix up soon:woot:
