I have a 94 2wd 5 speed and i got a E4OD outa a 95 4x4 (Plus the rest of the 4x4 system). Will the t-case sawp over to the 5 speed? What will i or would i need. Im not worried about money right now, I got time. Can Someone give me some pointers.:dunno: Thanks alot
they should bolt up. just replace the gasket between them
why would you want to swap from stick to auto.
I wish mine was a stick i had to rebuild my tranni and i had my truck since last sept.
if you selling it how much you want? a friend of mine might want it
I'm thinkin bout keepin it a stick, thats why im tryin to make sure that my 4x4 setup from my donar truck will bolt up to the 2wd truck i got now. im hoping to get all this done before winter hits cuz i cant drive my saturn thru another snow storm. i got no more sub frames to fix it again. haha
Electrical Ogre
To put the t-case on the 2WD ZF5, you will need a new mainshaft and extension housing. I had to do this to "rebuild" my ZF5 using a 2WD donor.
