1 - 7 of 7 Posts
k since i installed my guauges the transmission temp will rise tell it is pegged out at 250 degrees, in about 5-10 min idling,stop and go, or even cruising at 60. i just finished replacing the cooler bypass line and it did nothing, the truck does not shift hard, make noises or anything. do yall think the gauge is messed up or something because i can touch the side of the transmission and hold my hand there like nothing, also the transmission fluid looks clean and smells fine. what could it be i am starting to get adgitated:dunno::nunu::banging:
still under warranty?? if not, try swapping out the sensor.
aight il check it out in the morning but hey raul since i bought the gauges from you and thats what its been doing since i bought you think you could hook me up with some sort of warrenty
1 - 7 of 7 Posts
