1 - 9 of 9 Posts
I'm looking to replace both lines coming out of the transmission and I can't seem to find them. Any one have any part numbers or should I just go rubber between the rotted out section?
Partyman, yours is a 3C3Z-7R081-CB from the trans to the filter
What are you working on @Tiponinn
Sent from my SM-G960U using Tapatalk
Reactions: partyman97_3
Is the one from the trans to the cooler available?
That's the one from the trans forward to the remote filter
Remote filter to radiator is a 4C3Z-7B028-CA
Remote filter to external cooler is a 4C3Z-7B028-DA
and remote cooler to L/S of radiator is a 4C3Z-7C410-CA
Does this number get both lines coming of the tranny? On the truck it looks like 2 lines but everything I am finding on line looks like both lines come with this assembly.
Also, do I need to get a special tool to release the quick disconnects one the filter and the tranny. I fso, do you know what size I need to get?
Did the number change to 5C3Z-7R081-CA?
The 7R081 should be an assembly with both lines, I believe the 5C3Z is for the 05 and up which used a different external filter but I don't know for sure since I'm sitting in Applebees in Lodi sipping a Blue Moon
Lol, a hard core member of the org for sure, to interrupt a blue moon to help a fellow member out.
Reactions: BTL
1 - 9 of 9 Posts
