1 - 15 of 15 Posts
i was told by a buddy of mine that i will probably need a new transmission cooler when i go back out to Missouri towing my other truck.
im getting gauges to monitor the temp seeing how the truck has 300000 miles on it.
do you guys think a new tranny cooler would be of use or should i not bother spending the 200 or so dollars for it?
Discussion Starter · #2 ·
:bump:
anyone have any advice?
no one has any input?
duct tape & zip ties
Another trans cooler is only going to keep the trans fluid colder. It won't hurt nothing but your wallet a bit. I have three on my truck, my trans never gets hot.
I do suggest you get the external filter removed if you have one. They like to clog up, create resistance in the fluid flow.
thanks guys!
just what i needed!
I have heard that you can use a 6.0 cooler on the 7.3 trucks as a up grade.
Discussion Starter · #8 ·
really? does anyone know of this for sure?
Discussion Starter · #11 ·
how much do usually run for?
ive seen them new for around 300 bucks or so. powerstrokeshop.com has them for around that.
Discussion Starter · #14 ·
is there a specific year of the 6.0 i can use for the 7.3 or is it any year?
any year will work, you will just need some new fitting/couplers. Im not sure on what though, im sure raul can help ya out there
1 - 15 of 15 Posts
