1 - 1 of 1 Posts
where can i find out what the fluid path is in the
automatic transmission in a (95)psd,specifaly the
driver side port where you are suppose to plug a
temp. sending sensor,as i pulled out the sensor
that was there and no fluid came out hooked shop
vac to port to suck out anything that might be in
there nothing came out depth was only about 1/2
inch the sensor i got from Bank,s a lot longer then that ,thank,s whisky6
1 - 1 of 1 Posts
