1 - 2 of 2 Posts
Hey guys got a 2002 f350 7.3, the truck was in park at idle low range and 4x4 light appeared on the dash.4x4 selector is in 2 high position. Truck has not been in 4 wheel dr in months. Checked relays vacumn pump .. control module truck is stuck in 4 low what causes this mysterious breakdown ...
Administrator
that failure is going to be on your transfer case electrical shift motor or switch side
you can pull the tcase motor and manually shift it back ( google will dial you in)
then you can do some pinpoint test and see if the motor is being sent a signal or if it is a short or bad switch ETC
1 - 2 of 2 Posts
