1 - 10 of 10 Posts
4 by 4 light flashing. Truck would not move (assumed transfer in neutral) . Installed new shift motor. Truck works fine, however when going over a steep incline the 4 by 4 light starts flashing. The truck stays in gear. Any ideas?
Administrator
Explain truck would not move ? put in drive revs up but not move ?
Your t case has no selectable neutral function and for the 4x4 light to flash should indicate a readable code
but it sounds like something is not right inside the t case and the tranny may be going or trying to go into 4x4 but hubs unlocked so it was unnoticeable
Put the transmission in any gear and the truck would not move. Removed the transfer case shifting motor and manually put the transfer case in gear. Drove the truck in all modes ( 2 wheel, 4 low and high ) no apparent problems. Installed the new motor and the truck shifts and drives in all modes ( verified front axle engaging ). The mode light only flashes when going down a steep incline.
2008 Ford F-250 Harley Davidson 6.4 Dynamic Diesel stage 1 kit, ODD Intake, and way more. 💨
Are you coding for anything? Do you have a good scan tool? If not I’d bring it in and see if it’s coding for anything. Sounds electrical
Your problem could stem from something as simple as a vacuum leak to a major failure within the transfer case.
Only thing that would make sense for a decline or incline for that matter is fluid. But there is no level sensor for the transfer case so that rules that out.
Thanks. In a remote location so haven’t scanned yet. Will ASAP. Thinking electrical also.
Check the harness for the T-case and the connectors on the driver side fender well
ForScan would my choice of scanner tool
Reactions: Roccafellas
If you take the truck on trails it could have been a stick that caught a wire and loosened the pin connection on the connectors. Had it happen where hit a bump and things got wiered but no bumps all gravy. Found a wire was stretched just enough on one pin of a connector and it would jiggle loose on bumps. May be work checking the wire connector for the t-case more.
Discussion Starter · #10 ·
Thank you
1 - 10 of 10 Posts
