1 - 1 of 1 Posts
I am assuming that my Tranny is gone , i bought the truck assuming it was bad because that is how they sold it to me . I jacked the rear end in the air and i can turn the tires with very little resistance in every gear , even neutrual , no change . Somthing else i am noticing , when i turn the 4x4 switch , no lights light up either . Is this because the tranny output shaft has to engage the transfer case first ? Is there a possibility that it could be the transfer case? Just trying to rule everything out before i send it to the shop. I guess i could drop the drive shaft and the transfer case and see if if the out put shaft is spinning on the transmission.... any help would be appreciated .
Truck is an 01 PSD 4x4
1 - 1 of 1 Posts
