i have a 2000 f250 with an automatic. i am seeing 200* driving home from work. the temp outside is mid 90s. i recently had a flush and filter change done. is this normal to see temps this high(stock cooler)? i had a 6.0 cooler bought and the seller backed out.
this seems higher than what it should be on a stock truck. is a 26 row good enough or should i go ahead and spend the extra on a 31 row?
Hello. Your recirculation valve might be stuck an the fluid migh not be going through the cooler. Mine started doing this and I blanked it off and put a true cooler in , now it the temp dosnt get over 150 deg. How many km do you have on your transmission
53,000 miles.
ford says you are good up til around 270 degrees.
