I just had a performance tranny put in and now my gear shifter is loose. The guy said to there are two nuts under the steering column that I can tighten? Anyone hear of this before.
Discussion Starter #2
I am going to look under the truck today, because I think it has to do with the cable. Any inputs?
it is probably the bolts he is talking about. if you drop the column you can see where the shifter linkage runs down teh column. on the back side there are two bolts, probably loose. This happend to my old work truck. Could not shift all the way down into 1st gear and sometimes you had to play with it to get it in park.
