2003 Excursion 6.0 with Torqshift. 163k miles.
After a long sit the trans shifts semi hard. Under power it won't shift sometimes and I can let off and it will shift and then keep going. Once it warms up shifts normal and smooth. I have read a bit on this issue and going to try the TSB adapt learning sequence this weekend (batteries unplugged for a while doing maint.). Also am going to change the fluid and external filter. Prob. need to do a flush but want to start small first.
But before I do that I want to get some starting temp readings. I bought AE with the Ford bundle and have it set up to watch EOT/ECT/FICM but can't seem to find the trans temp sensor in the live data drop downs. Are there some special settings that I need to change to see that? Maybe I just haven't poked at it enough.
Give me a slap on the head if this has already been covered. Thanks.
