I am replacing the soft hoses on my 2007 trans cooler, the driver side I can source new OEM but the passenger side I can’t seem to find. The passenger side has developed a small leak in the soft hose during cold weather. The hose connects to the trans cooler and then to the line with a clamp on each end. Anyone know what size hose (diameter) I need?
TIA
-Nick
Vendor
They are 1/2". Just go to Napa and get the Gates transmission hose as it is rated for 400psi and a bit higher temp. 1/2 to 1/2 pushlok hose menders work well if you need those. Dont use the normal hose barbs you get from the local hardware store.
Thank you. I was going to use 4 worm gear clamps or the factory spring clamps that are already on it.
