Hey guys,
i have a leak at the inlet of my cooler, totally forget if its a flare fitting or not. i didnt pull it apart today as i did not have time to deal with it and make a mess. i tightened it a little bit more but i still have a leak. im thinking about replacing the cooler and the lines just to be safe. any body know if i can use rubber lines or where i can get a set of steel ones? also any thoughts on it being the cooler or the lines that are causing the leak.
thank you
Will
thank you
Will
