Trans. Cooler , I need to put on a external oil cooler so I have taken off th...
Can I use the factory Trans cooler as a oil cooler for my 7.3
Doesn't Even Care
No need to, plus I don't know how you would. If your oil is running too hot then you need to change the cooler Ron the side of the block out, cause its clogged up
Thanks for the info. Yes my oil is running hot and I am going to put a new cooler on but I would like to put on a external oil cooler if the Trans. Cooler I took off would work as a oil cooler or spend the few bucks and bye a new one
Sent from AutoGuide.com Free App[email protected] bresnan .net
