1 - 1 of 1 Posts
Hopefully one of you Transmission Experts can narrow this down.
I have been having this Tranny issue now going on two years. First, yes it probably needs a complete rebuild but I am hoping to narrow down a fix as the guy I would have rebuild the tranny, (John Wood) is no longer doing customer service at his shop. He has only a couple of authorized guys and the one located near me does not have the best feed back for work he has done. That Said;
The issue: Tranny will not engage in any forward gears, only reverse when its cold. The tranny oil and the engine coolant has to get to operating temperature. I then can put it into drive hit the accelerator once or twice real quick and the tranny engages and runs fine after that. As long as the engine is hot this "hack" works on getting the Tranny engaged. If I try and engage when everything is cold and rev. the engine I get a whining sound.
Things I have done. I flushed the tranny and changed the filter. Problem is still there. Here is the list of codes I pulled Last Night. In your best guess would this be just a bad Torque Convertor, possibly the lock up Solenoid, wiring issue etc... Like I noted above once the engine reaches operating temperature I can get the Tranny to engage. Regarding the P1876 error. I can hear the Drive Solenoid clicking when I turn the on the fly switch, just wondering why I am getting that error also.
Also on the
===OBDII DTC ===
Successful DTC reading, no error codes found
Module: On Board Diagnostic II
===END OBDII===
===IC DTC B1352===
Code: B1352 - Ignition key in circuit fault
Module: Instrument Cluster
Diagnostic Trouble Code details
===END IC===
===PCM DTC P0603===
Code: P0603 - Power interruption on KAPWR circuit.
Module: Powertrain Control Module
Open KAPWRcircuit.
Loose/poor battery connections at the battery and engine block.
This DTC may be caused by :
If a recent PCM disconnect or battery disconnect is suspected no action is required unless the code continues to appear after being cleared.
Reprogramming can cause this code. If reprogramming was done clear codes and release vehicle.
Improper connection
===END PCM===
===PCM DTC P1247===
Code: P1247 - Turbo Boost Pressure Low
Low boost pressure
Possible causes are:
Air leaks at the intake manifold or crossover tubes
Map Sensor
PCM
Follow the routines in the service manual to resolve the DTC listed.
===END PCM===
===PCM DTC P0741===
Code: P0741 - TCC System Performance. Torque converter slip is greater than expected
internal mechanical/hydraulic failure
TCC
Refer to the workshop manual for further diagnosis and repair.
===END PCM===
===PAM DTC ===
Module: Parking Aid Module
===END PAM===
===OTC DTC B1342===
Code: B1342 - ECU internal fault
Module: Overhead Trip Computer
ECU internal fault
===END OTC===
===RCM DTC B1869===
Code: B1869 - Lamp Air Bag Warning Indicator circuit failure
Module: Restraint Control Module
--- Possible Causes --------
Air Bag Warning Lamp Indicator Circuit Open
Warning Indicator inoperative -----------------------------
- Circuit Failure between AirBag Warning Lamp & Power Distribution
-Circuit Failure between Air Bag Warning Lamp & AirBag Module
Warning Indicator always ON ---------------------------
- Short to GND between AirBag Warning Lamp & AirBag Module
-Suspect Fuse AirBag Warning Lamp AirBag Module
Check the instrument cluster connections for shorts etc.
===END RCM===
===GEM DTC P1876===
Code: P1876 - Transfer Case 2-Wheel Drive Solenoid Circuit Open Or Short To Ground
Module: Generic Electronic Module
===END GEM===
===ABS DTC ===
Module: Antilock braking system
===END ABS===
1 - 1 of 1 Posts
