1 - 2 of 2 Posts
I have a plate and fin style cooler that has a 18,000 gvw rating on it. I was wondering should I install with with the factory tube style one and keep them both? Or replace the factory one with the new one? Or I guess not even worry about it. I typically pull about 7000 lbs and the truck is stock. Thanks
Shaking the Bush Boss
The cooler you keep the trans, the better. If you already have the other cooler, run both of them. Personally, I'm using one from a 6.0, and ditched the stock cooler.
1 - 2 of 2 Posts
