1 - 15 of 15 Posts
Pulling my gooseneck trailer this evening and this message came on.Lights and brakes were still working.A few miles down the road " trailer connected" message came on.It done this once more before I got home.Trailer wiring harness connection good and tight.Any suggestions to check?
I'd try blowing out the plug with some compressed air. It's possible something got in there and disrupted the circuit. Could be a simple fix.
You have an unusual problem. I would think there is a loose connection or bulb socket in the trailer somewhere causing this message.
You will need to collect more info to find it. Does the message appear right after a bump or rough bridge?? Maybe it happens after aggressive braking??
Sounds like the circuit is being broken and then reconnecting itself, , , prolly on the trailer.
I can say from experience that a running light out will not do this. I had a side clearance light completely corrode away the terminals in the socket and the light was out but no message.
I think the brake circuit may be the place to look??
Good Luck with it
This has happened to me twice. All I did was unplug the trailer from the truck and plug it back in. That took care of the problem both times so, it does sound like a connection problem.
Don't forget, could be magnet wires in the hubs.
I made my Samsung SGH-I997 send this.
Discussion Starter · #7 ·
The problem did occur I noticed the second time after hitting a rough section of road.
I pulled my bumper pull trailer this evening and no problems so the problem must be in the plug in the bed or the trailer.It will be a few days before I have a chance to check it out.Thanks for the suggestions.
Its probably an old or dirty/corroded plug on the trailer. All my trailers would do this in extreme cold or wet slushy conditions. I would change the plugs on the trailers every time I get a new truck (2-3 years) and that would pretty much take care of the problem.
You losing a ground between you truck and trailer. I have had a couple of trailers do this because of my B&W hitch. What I have done is make sure that my trailer is grounded to its self. Now I don't have this problem.
ditto :):):)
Happens frequently to me too to going over big bumps or a rough section of road. Trailer disconnected and Trailer connected messages. Haven't found a fix yet. May look into the trailer grounding previous poster mentioned and spray off the connections with some eletrical contact cleaner.
Next time you hook up to your trailer, when you plug it in put a Ziptie around
the pigtail and the plug in cover.
Doug
Keep in mind the message only relates to the Braking system. Could be a faulty magnet in any of the Brake assemblies, or any one of the magnets losing it's ground.
I had this same problem with my truck, I hooked up a pair of jumper cables to the trailer and then the other two ends to a good ground on my truck and the problem went away, so I did up a new ground wire on my trucks plug and the problem has not come back.:rofl:
Most of the problems I have seen is because ,either with gooseneck or bumper trailers, the trailers are losing ground because the hitch is not making a good ground, either it's moving around to much or it's a rusted ball/hitch. My B&W is the worst. But since I have ground all my trailers back to there self that has fixed it.
1 - 15 of 15 Posts
