So, the rear driveshaft in my truck fell out the other day on my way to work. i have to have the driveshaft retubed cuz it was bent and the pinion flange replaced, and i'm replacing the u-joint with a stock spicer... my truck has a 6 in lift on it and i think that part of the drive shaft failure is do to my lift and the slip yokes aren't engaged fully with the shaft on the carrier bearing and axle wrap flexing the joints too much.
that being said, i am thinking about getting a set of trac bars for my truck to help eliminate the axle wrap. what kind of bars should i get? i have been thinking about fabtech bars because i like the double tube design, i don't like just the single bars. i like the look of the rize bars but they only come for 05-07, will they fit on an 02? is there a way to retrofit them? thanks for the help everyone.
