1 - 7 of 7 Posts
wont a dual steering stabilizer inhibit bump steer? which is/was gonna be my next thread.
isnt a track bar needed to center the axle after a level?
OK, deleted that post....my bad.
Yes you need a adj track bar..either one works ..the Top Gun bar is a Pure Performance track bar and doesn't need to be removed to adjust.
Dual SS help hunting from wider tires and loose components..not bump steer.
You will need castor correction with a 2.5" lift or get a complete Pure Performance 4 link kit and adjust to 4.5-6*
If I can help let me know.
Not using drop brackets or drop pitman arms unless useinf both at the same time and both designed to work together...that will keeo the angles equal.
Neither one needed till a 6" lift on a '05 up.
1 - 7 of 7 Posts
