1 - 10 of 10 Posts
I've tried everything, even brought it to two shops. One refused to do it and the other broke a $400 press trying to get it out. It needs to be replaced badly, does anyone have any tips??
I'm interested too since mine needs replacement. I'm assuming that since they broke a $400 press that my Harbor Freight press isn't up to the task! :hehe:
5lb sledge? just the puller alone isn't going to do anything but the shock from the hammer should
Heat it up with a tourch first then press it out...
doesnt sound fun
yep, heat and cave man muscle.
Did you ever get it out?
I had used a regular ball joint press but I had to cut one of the coupler things in half to stack them to make it deep enough...the stud on the stock joint is very long and I couldnt find a press deep enough.
I'm kinda curious on this since I thought the track bar had bushings not ball joints. Mine had bad bushings but I ended up buying a whole new track bar.
The track BAR has a bushing on the frame end...but it goes onto a balljoint thats pressed into the AXLE...hes trying to change out that ball joint.
I'm still running the bad ball joint because I couldn't get it out. I'm just going to bite the bullet and have a shop swap it out for me. I'm done screwing with it.
1 - 10 of 10 Posts
