I might advise the 6.0 transmission cooler. There are many who claim a deeper pan, converter “upgrade” and valve body “upgrade” will yield longevity for the 4r100. Service history is a significant factor.
The 7.3l is certainly capable of towing 10k tell us more about the truck though? Any mods, lift kits, tires, tuning, 4x4 long bed, short bed 2wd?Never have done any heavy towing with a 7.3 and i dont want to kill the transmission. Do i need to tow with the overdrive off or can i just leave it in drive and let it do its own thing? Or? I am use to towing with a 6.0 and just letting it do its thing in tow/haul but those transmissions are much tougher. Thanks in advance for any advice.
I just traded my f350 CC long bed 460 to get my new to me 6.0. That old ford would tow a house with the 5 speed and a super low granny gear. I used it as a 4 speed unless I was towing heavy.I pulled lots of heavy loads back in the day with the 454 and 460 gassers, that 4-5mpg did get old but I could out-pull the 6.9 diesels and that was all that counted at the time…
I lived in Valdez during the days of the pipeline and I gotta say that Valdez was the closest thing to the western "boom Towns" as depicted in countless western movies. No doubt it probably had something to do with pipeline money…Fairbanks was no slouch in that department either…lolBack in 95 I bought a new 7.3 because I had a 30’ x 10’ ocean boat but I lived in the interior of Alaska and was planning on fishing in Valdez. A buddy of mine had a 7.5 gas truck that we towed with it the first time down and the fuel mileage was horrendous. We had to carry a 30 gallon barrel of fuel in the bed because we couldn’t make it between some gas stations without running out of gas. He didn’t have an external tank but had the dual tanks on his truck still wasn’t enough. I think we averaged about 4 miles to the gallon with his truck. So after that fiasco I bought the diesel. It averaged 12mpg which meant we didn’t have to carry any extra fuel. The road to Valdez is hilly to mountainous with a few flat spots and that truck did great for four years, but the winters killed my enthusiasm for the truck it wouldn’t stay running in Fairbanks extreme temps. With all that said I had no problems with the truck or the transmission, all stock, towing my boat. Your mileage may vary.
The 5R110 transmission is much tougher because Ford put a significantly larger trans cooler and better torque converter in them. If you are driving up n down hills in a predominantly 55mph speed limit, then turn off the OD. But if you are driving on flat highway and interstate, then leave the OD turned on.Never have done any heavy towing with a 7.3 and i dont want to kill the transmission. Do i need to tow with the overdrive off or can i just leave it in drive and let it do its own thing? Or? I am use to towing with a 6.0 and just letting it do its thing in tow/haul but those transmissions are much tougher. Thanks in advance for any advice.
