If you already know this skip on by, for everyone else I just thought I'd share. So I work in an auto plant. We have periodic classes to "retrain" on many topics. An important one is torque. On themany fasteners that have NHTSA required torque recorded values we have to be extra careful. I have seen many times on these forums people saying to use WD40 on CAC boots. This is fine for removal as long as you thoroughly clean and dry them before re-torqueing them. Here is why, bolts have an assigned amount of friction to get to correct clamping force. when you use things like silicon (WD40), oils, wax, or even spit (yes we get this in automotive), your torque value is inccredibly off because the lack of bolt thread friction. I am attaching a photo of what only slight amounts of wax or even spit can do to a bolt. When we go through the class we train in, we see bolt torque triple over what the value is on the wrench after it is torqued to what even our sophisticated computer controled torque wrenchs hit desired torque. When we put a pressure pad between them to get actual clamp force we see the real story of what happens. I'll attach some pictures of what bolts look like that have "hit" torque but clamp force is overly high after using a friction modifier.
