^^^^^ Correct; the purpose is to have cleaner oil, if only by a little bit (1 qt / 15), for the whole engine; we seem, as owners of HEUI engines, to focus on the importance of the hydraulic quality of our oil, and tend to forget that it also is the main crankcase lube, just like any other engine. The notion of any benefit specifically to the injection system is just another of Bill's giggle-test moments.
As for that "oil analysis" video, that difference could be for any number of reasons; maybe at the moment one sample is warmer than the other, or the crankcase sample came from just when he started to drain it, or maybe it was the last bit drained. I bet if both were subjected to a true chemical UOA, they'd reveal little if any difference. Blackstone Labs instructs you to take your sample from the "middle" of the drain-out, not right when you remove the plug, and not right when the last bit is running out.
