21 - 31 of 31 Posts
Administrator
O.K. I've cooled down from being accused of making up this mpg # .
Don't let the internet get you worked up bud, it's not that serious.
Witness
What is your mpg when not towing? I get “good” mileage usually around 17 when not towing. However, when I tow I usually get between 10-11 and less if I drive over 70. I have a drw, 2WD with 3.73 and I’ve noticed it doesn’t matter the weight of the trailer at all. When I towed an old airstream (5200 lbs) with a diesel excursion I got 10-11. When I pulled larger bumper pull TTs, same. Now my big fifth wheel gets 10-11.
My point is your mileage is on par with the rest of ours and your friends mileage is an outlier.
Edit...I see you get 16 unloaded.
BTW,
I just did my weight loss and I will report back if I see any increase in fuel economy after I tow this weekend. My unloaded mileage did not increase :(
Discussion Starter #24
My trucks work, I don't haul campers in the hammer lane.
We've asked for info... Post pics of his rig and his MPG display in the truck... I really want to know all the details about this set up.
Maybe this is where I'm messing up,,,,,,is 70-73 mph towing my 5,000 pound boat considered fast? Hammer lane? M.C. Hammer, Hammer time, sledge hammer, claw hammer?
O.K. I've cooled down from being accused of making up this mpg # my co-worker says he gets. I am not a story teller, I am not a lair, I don't even stretch facts, I told you guys what I was told. He is a straight up guy and mpg #'s I have read on line appeared to be the same as his, or so I thought until I bought the truck and joined this forum. I solved my TERRIBLE 26 gallon tank problem by throwing $1,500.00 at a 50 gallon tank, best move I made.
Yes, I've complained about my milage since I got it and NO ONE else seems to get the same bad mpg that I get. I'm 57 years old, I drive it like a 70 year old grandma and maintain the daylights out of it. I have every fuel rcpt and every rcpt for every add-on I've done. I keep a log of every fill up and the mpg in said log. I changed oil at 5,000 and 10,000 ( fuel filter also ) and getting ready to change at 15,000 in about a month. The truck has been washed so much you would laugh if you lived beside me and saw all the washings. Wife and I have never eaten or drank anything in it. I installed a bed rug over the factory Hercules lining, whatever it's called. Best LEONARD cap installed 3rd week of ownership.
SO, without wasting my time to read all these posts again, I believe the guy above said he ONLY got 9.5 or 10 towing his 13,000 pound 5th wheel. That,,, in and of itself,,, tells me that my 9 mpg towing 5,000 pounds SUCKS !!! I'm on flat road the 2 hours to the ocean and 2 hours back. Drove to Florida, not towing got 16-18 @ 75mph on cruise. Again, I got that with a gasser 2003 Tahoe.
The truck rides great, or so I think, has power forever and has every creature comfort, but with mpg as disappointing as it is to ME, buying this truck was a mistake on my part.
I honestly believe the 3.5 Ecoboost could do better mpg-wise, but I don't know. Power would suck tho'.
If you are referring to me I said 9-9.5 and that is towing at 67mph. MPH makes a big difference. Slowing down just 4mph I can get about 1-1.5mpg better. I would never consider towing above 70mph as I don't think I would even get over 8mpg.
Please let me know what your co-worker is doing to his truck to get 13mpg going 73mph. I'll bet I could get close to 15 doing 65mph if I had his secret.
Yes that is VERY fast. Check your trailer tires speed rating. If they are ST tires they will probably only be rated for a MAX 65mph.
I seriously only go 64mph towing unless we are a little short on time. Then I will push it to 67 but NEVER over that. I replaced my trailer tires to ones rated for 87mph.
Discussion Starter #28
Hammer lane is putting the hammer down in the left lane.
Yes, I knew that, I just didn't think 73 mph was putting the hammer down. My bad. And I guess I need to re-think how fast is too fast.
And I will be checking with friend/co-worker to make sure I haven't misunderstood him about his speed.
HE uses Archoil additive and oil booster or whatever it's called at oil change time. Has Michelin tires and same reared as me.
Administrator
I never said you were wrong. I never said the op was wrong. That has nothing to do with what I posted. Just delete my membership and all info related to it like I asked. Thank you.
21 - 31 of 31 Posts
