Hello Gents,
On my second F-250 now. Just purchased a 2015. I just put on my tires from my old 2010 and have rubbing on the wells when I turn - I know this is a much talked about topic but I'd really like to crack this nut. It's like a puzzle of utility and looks. Pictures and data speak volumes when making these decisions, so I'll ad both. The current wheel setup is: 35" x 12.5" Toyo MTs with 20x10 SOTA wheels with a negative 12 backspace. I've used the stock rims with the same tires and had no rubbing, but this negative offset is causing rubbing on turns. I don't like how far in the old stock rims sit. My 250 has a leveling kit in the front and I'm about to add blocks to the back to truly level. This may help with some rubbing on the back of the well but it's still too close for comfort on the inside of the bumper.
So, I'd like to hear suggestions but I think I have two options: go with a 0 offset rim (how does that look?) or get a lift (but I want to know what's the least lift I could get?) Thanks in advance!
