Well, here is my problem. Battery drain.
I replaced both batteries for new motorcraft stock ones. I looked in the forum how to and checked them with a meter.
I used a UNI-T UT33C meter, set in "10 A", unplugged the negative of both batteries and the meter showed 1.60 and 1.40 tops. Too much I think. Both Bats are fully charged, 12.3V.
Tomorrow I´ll start unplugging fuses to find where is the leak. The only non stock electric are an alarm and a hot wire for towing.
Any advice on what should I read in the amp meter?.
arriero
Hold on.
If you had both neg terminals off at the same time, I assure you that there was zero(0) amps flowing/drain. You need to start over.
I closed the circuit conecting the meter terminals with the battery negative and the negative cable. Then, it showed 1.6 and 1.4. Is that the right way to test it?
Oh ok. Yeah that's right. I had a vision of both neg term in the air and current flowing...Nevermind. But yes that is a way to do it, and if you had 1.5Adc, that may be a bit high. I've never measured mine, but I would SWAG that it would be 1 A or so. Everything with a memory, ie the radio, PCM/ECM, will draw several milliamps, but shouldn't add up to 1.6A. Have you an alarm, aftermarket NAV, aftermarket entertainment or lighting?
Seems high, but I have never checked mine. Your batteries aren't fully charged though. 12.6-12.7 is full charge on a car battery. I assume that you've made sure the alternator is working appropriately? I had a drain on mine that I was getting ready to chase down and found my glove box light switch wasn't getting pressed in far enough....found it one night in the dark when I saw light coming out of the crack between the glove box door and the dash.
A good way to start chasing the draw is to have a buddy/wife/etc watch the meter and start pulling fuses one at a time and see which ones drop the amp draw off. Then see what runs off those circuits and go from there. Good luck with it! I hate chasing electrical gremlins.
-Aaron
Well, i have an alarm. Is the only electric extra that has my truck. Ill disconect it and check again.
Im planning to put a second fuse box for extras, so I dont mess with the original wiring.
Sent from my iPhone using AG Free
