Okay, I know the cold tire pressure setting listed on the tires is what the tires 'should' be set for...
...My question is:
What are y'all really running? For example, if the tires list 80psi as the cold tire pressure, what psi would you run the tires at for a normal mix of pavement / dirt road with an occasional 4wd road??
(had a TPMS Low Pressure warning over the weekend. Ended up that 3 of 4 tires were 20psi below 'cold' psi listed on the tire)
...My question is:
