First and foremost...
I want to thank everyone on PowerStroke.org for all of the great information. I have an 07 F350 6.0L and an 06 F350 6.0L. I was able to replace the oil cooler and install an EGR delete last week in the 07 in the parking lot of my hotel 800 miles from home thanks to all of you.
So now for my current question...
I have Goodyear Wrangler LT275/70R18 125R Load Range E tires on my 06 with a max pressure of 80 PSI. The Door Jamb sticker says to run the front at 65PSI and the rear at 75 PSI.
What would you recommend for best MPGs and Long tire life. Also, I use this mostly as a daily driver and occasionally for long haul towing. However I can change the pressures when I am going to tow if necessary.
Thanks for any input you can give me.
Ryan
Ryan
