1 - 20 of 30 Posts
Well I was finally convinced to get a set of gauges (3). I want to get a trani temp. pyro (EGT gauge) and boost. I can install the pillar and all of that but I do not understand or know where to tap in to get the readings from. if im not specific enough please just tell me and ill try to explain further. any help is appreciated! :icon_ford:
a truck
They arent too hard I had all my guages in my 95 tapped in, wired and installed in the pillar with all the lighting wired and everything in three hours.
For the pyro you are going to have to drill and tap into the exhaust manifold, the best way is to get under the truck and drill into the drivers side manifold. It is not that easy to reach but if you take off the front driveshaft if you truck is 4wd then you should be able to get it. Then you just run the wire that comes with the gauge to the back of the gauge.
For the tranny temp, on the drivers side of the tranny right above the tranny pan, there is a probe that is normally used for testing. What you do is remove the plug in there and install the probe that comes with the tranny gauge. Then run that wire to the back of the gauge.
Then for the boost guage you are going to splice into the rubber hose running to the MAP sensor on the passenger side of the firewall. Then run the boost line to the back of the boost guage.
Hope this helps let me know if you have any more questions
I am going to be in the same process as soon as I get my truck back from the dealer. I'm not sure where but I am a marine diesel mechanic so it shouldn't be too difficult to figure out. From what I understand the pyro sender needs to be adapted but I might be wrong; wait till I get my truck i'll figure it out
a truck
It is all pretty easy to figure out, the only difficult one is the pyro since you have to drill and tap the manifold.
What do you mean by adapting the pyro sender.
Also I see you have an 05 for that you are also going to have to drill and tap the boost tube I am pretty sure since you can only splice into the MAP line on the 94-97's and Im not to sure about the tranny connection but I think it is still a transducer you put in the diagnostic port.
As soon as I get the truck back I'll take a look; by the way, what's the best source for the gauges?
drilling and taping is my hobbie pretty much. I restore old beat up dirt bikes and dril and tap dam near everything. that will be my easiest part. Im not too good with the wiring.
O good thing you brought that up smarinediesel. I have no clue where to buy the gauges and the pillar.
a truck
For your 97 Ive found the dual guage pillar but pm him and ask him about the triple guage and Im pretty sure he can hook you up he has great customer service and prices, His username is [email protected]
Thanks for the info PSD0389. I appreciate it!!!
a truck
No problem man thats what we are here for, let me know if you have any more questions on the guage installation or anything else
Hope it all works out well for ya:thumb:
Discussion Starter #13
Thanks for all the help guys. So Raul, Should i buy them off your site? or go directly threw you?
Not to hijack the post, but Raul can you get, and is the price comperable on the GS series autometer gauges?
Personaly I think they look the closest to the stock gauges in our OBS's.
Discussion Starter #17
Well guys I just ordered up the triple gauge pillar and Raul is the way to go! Very fast with help and can assist anytime. Definetly order from him! I will make a new post with installation looking for help and double checking! thanks guys!
Great thread, but I was wondering if there is a better way to connect the boost guage? I had mine connected to the boost hose, but it keeps getting blown off. and that really affects the way the engine runs. Thanks in addvance
Discussion Starter #19
i THINK YOU FORGOT TO PUT THE CRUSH "THINGY" IN THE FITTING THAT CRUSHES THE HOSE THAT GOES TO YOUR GAUGE...THAT WOULD BE MY GUESS, YOU COULD ALSO CONNECT THREW THE MAP SENSOR BUT IDK HOW TO DO THAT.
is the transmission temp the same on the e40d auto do you have or know where to get pics
1 - 20 of 30 Posts
