All well worth it, especially if you plan to keep the truck. Doing a lot of work yourself will make the cost even easier to your wallet.
Injector Set | Alliant Power 94.5-03 7.3L Reman AC Injectors - ALLP-7001-PP |
Turbo Wheel/Rebuild |
94.5-03 7.3L KC Turbos S300 Turbine/Billet Wheel Kit*THIS IS A DROP IN WHEEL KIT, SO NO MODIFICATIONS ARE NEEDED. * - Drop in ready - Upgraded 360 bearing - Quicker spool up - More air flow - Rebuild kit included KC Billet compressor wheel balanced with our new s300 style Turbine wheel. The entire assembly comes balanced and ready to install...
Valve Cover Gasket |
FORD Under Valve Cover Gasket - 7.3L 94.5-97 OBS - F4TZ6584A.yith-wcbr-brands-logo { margin-top: -155px !important;} Genuine Ford OEM 94.5-97 replacement Under Valve Cover gasket This is a Genuine Ford OEM gasket. In order to replace both sides please choose 2 qty. There actually is a difference in quality compared to Dorman, and you will receive a true...
Injector/Glow Harness | FORD UVC Injector & Glow Plug Harness 7.3L 94.5-97 OBS - F4TZ9D930K |
Tranny Cooler | FORD GENUINE OEM 26 ROW TRANSMISSION COOLER - 5C3Z7A095CA |
Hydra Chip Tuner |
PHP-HYDRAFREE STOCK TUNES: Your Hydra Chip comes with access to the Power Hungry Performance server by downloading the Hydraflash App at no additional cost to download your tunes. Examples of the stock tunes that already come with the Hydra Chip are listed in the table at the bottom of this page. Note**...
I have changed hundreds of injectors and never rotated them to break them loose. If the injector cup where to come out with the injector, it needed replacedkevilay-4633: I'm not sure if the videos will show this or not . . . But, rotate the injectors ever so slightly in the bore back and forth several times to help break the o'ring stiction before you pull them. They won't rotate much but by doing this it reduces the risk of having the injector cup pull out with the injector. Good luck.
