1 - 14 of 14 Posts
08 f350 6.4 I thought I had bad starter and it was not engaging but after replacing it I am still left with the same issues. my question is what is the easiest way to see if it is the flywheel. I have a feeling I will be dropping the starter again to see and am not looking forward to it:surprise:
The starter runs? but does not engage the gears? -- or nothing happening?
Dunno if the 6.4 has a flywheel inspection cover or not - you could pull the starter off and use a screw driver to rotate the flywheel to see if it is loose or the gear is buggered up
Not engaging should make a bad grinding sound
yea I am dreading pulling it off , but I am thinking it is my only option. it sounds like it is not engaging. when it was running I lost power and heard a grind and it was on a hook after that. truck has 157000 on it
Mr. Crossthread
Driver's side right behind the oil dipstick will be a rubber cover, take that off and use a mirror to look at the flywheel. Have someone turn the engine over by hand at one of the crank balancer bolts (18mm).
Mr. Crossthread
my new house will most defintly have a garage, had enough of working outside in montana
My son just put a 40x70 with water heat in the floor -- of course hay bales and a tarp works OK too, with the cardboard creeper -- livin high right there
Dont forget the space heater with fire extinguisher strapped to your leg :look:
Said he put in a new flex plate and converter - surely would have checked the crank adapter?
I have had broken cranks sound like that, you can rock the flywheel back and forth a little to tell if there is "slack"
1 - 14 of 14 Posts
