1 - 19 of 19 Posts
I have a couple boxes of parts waiting to be installed into my 2004 6.0.
Oil stand pipes, Rail plugs, New injector o-rings. Then on the oil cooler half. New oil cooler, intake gaskets, egr delete, coolant filter, turbo oil feed tube and return tube.
Still have to get the 4 gallons of rotella, along with 3 gallons of ELC coolant, plus water and vc9 to flush the coolant the crap out so it doesn't mess up my new oil cooler. I should do this before the tear down right?
Trying to get a list of tools I need, thread locker, anything I need for the gaskets, anti seize, since I don't have any of my own and they will all be borrowed mostly from my dad's tools he keeps at work, gonnna hopefully start to tear it down come tomorrow. As well as tools I can borrow here from my Continental Airlines haha. :thumb:
Anything I can use for help is greatly appreciated. I have the 6.0 bible on my laptop. Just wondering if anything more in depth would help. Any threads for reference are good too.
This will be my first time actually working on my own vehicle and on top of that doing some larger fixes. Any help is greatly appreciated.
Just finished up last night, but now I can't get the truck to turn over. Batteries where a bit low, so I charged them up. The only codes I'm blowing right now are 2 egr codes for my non existant egr. And a p0231 code.
It is cranking but not turning over. Any ideas? Too much air in my fuel lines or something?
After posting, I went and looked up your code.
P0231: Fuel Pump Relay Driver Circuit Failure.
Check that the fuel filter housing if filling with fuel when you turn the key on. (your gonna need a helper for that one)
Before lowering your new oil cooler into place, did you add almost a full quart to the HPOP reservoir (area under the screen)? If not it will take some extended crank times to fire it up.
Now that I didn't do. So just keep at it? Storming now. So I won't be able to mess with it for a bit.
P0231 Fuel Pump Fuel pump secondary circuit low Fuse, relay, inertia switch, fuel pump, open/short circuit. Would that by any chance cause an issue to starting her back up?
Yep, no fuel, no start. See above post about checking for fuel flow
Double check all the electrical connections you unplugged. I had a crapload of codes when I finished. Found that I did not get all the FICM plugs seated and locked in. Those plugs can be a royal pain in the arse.
Ya it was filling up fine, no idea what next. :/ Only plug I can think of is the plug for the EGR valve. I'll double check everything once this storm blows over.
Check your fuel reset button on the passenger side kick panel. When I did my egr delete and oil cooler I filled up the reservoir and it still wouldn't pop off so I pushed the fuel reset and it fired right up.
I'll have a look for that switch in a second.
Report back in a few!
I didn't think the diesel's had the fuel reset, I know my '03 doesn't have one there.
Also, just a pet peeve of mine, turning over and cranking are the same thing. You mean it won't fire/start.
Discussion Starter #12 (Edited)
Not exactly sure on the location of this switch or what it looks like. Anyone have a picture by any chance?
*edit : I found a button/ switch behind the kick panel. It was in the down position popped it up. Nothing in either position.
Discussion Starter #13
Ya no fire/start. :doh:
Don't bother with the switch. You said that the fuel filter housing fills with fuel, so the pump is working. That switch is on the passenger side, inside the truck, down by your feet is the "kick panel." Look at the panel and you will see a section that bumps out, stick your finger in there and you will feel the reset button.
Turn it over for 20-30 seconds at a time. Crank for 20, rest for 30, crank for 20, rest for 30 until it fires. You did not prime the HPOP and will have to do that before it will start. It can take up to 3 minutes of cranking to get it to go.
Motor Head.
BTW ,thanks for this tip.I just put my oil cooler in a few minutes ago and i made sure to do the above...
No problem. That tip is in the link in my signature.
Some of those notes in that link are out of order timewise in relation to the way you would do this job. They were just my scatterbrain scribbles that I should have re-arranged in order.....
Discussion Starter #17
Gotta charge my batteries, I never did that in succession. :doh:
Storm is still kicking gotta wait now.
Discussion Starter #18
Any other possibilities besides priming the hpop? Won't be back to working on it until tomorrow afternoon that is if it doesn't rain. Gotta love Florida.
Of course there are other things it could be! BUT, unless you get a bunch of codes, nope.
If you do get a bunch of wierd codes, check the plugs on the FICM to make sure they are set and locked. I had that problem.
1 - 19 of 19 Posts
