:mad:just started from under the truck... when tapping the brakes going around a left turn or hell even drivening straight. i get a metal to metal da-dunk its not constant but its sound that i can feel thru the floor boards. nothing looks broken or loose get a better look tommrow dark and been raining. im leaning towards carrierbering or a bushing thats worn out???? :banging:
never hurts to check tho thanks...... i did just get bigger tires too 315/75/16 ive noticed a little diffrence in its performce since then but dont see how they could be the cause of any problems unless there was one starting and they helped it along???
ok run it again down the road found two things one it makes a clicking from the front right tire its not constant but when it starts it stays steady till i slow down.. next how much play should you have in the carrier bearing housing ???? i have some slop in there never messed with them before so not really sure.
Check your exhaust hangers. I have an MBRP 5" and one of the hanger studs wound up slipping the hanger bushing and started banging on my frame....was annoying as heck and could feel it through the floor boards.
yeah i checked those todfay shook the hell out of it no noise its up in the front we found but everything seems good touch and feel but going down the road is diffrent story
