I just had my TFT go out on my 05 6.0 and I went to the dealership bought the parts to change it out and service the trannie. Everything went well got it all replaced and put back together but i still have the CEL on and i can't get it to go off..I am getting the codes PO700, PO710, P0713. What could be the cause for this. I have tried to turn off the codes with my livewire but my livewire is currently locked...still reads and i thought it would still clear codes. But I can't get it to change anything..Looked in the 6.0 bible for diagnostic codes can't find PO713 and PO710. Help Needed thanks
Numbers P0710, P0711, P0712 and P0713 are all TFT sensor codes.
710, 712 and 713 are "Voltage drop across the TFT sensor exceeds scale set for temperature (315° F)". Your symptom may be the loss of 5th and 6th gear.
P0711 is "PCM detected no change in the TFT during operation. TFT value stuck at some normal reading."
You will have to find a way to clear the codes.
