1 - 13 of 13 Posts
Hey guys this is my first post here. I'm looking to buy a 94-97 PSD F250 as soon as possible but they're pretty hard to find in my area, and in good condition. I actually went and checked one out yesterday and took it out for about 20 mins on a test drive (had 70,000 miles)
I've never driven an F250 before, currently I drive a 1997 GMC sierra so I'm very used to that. How are these trucks supposed to drive and feel? This one seemed to be hard at shifting, you could feel the gears change ..almost like a thud. I don't think thats normal. The brakes felt hard to press down, they stopped just fine but the pedal didn't move much, just apply force and it stops (on the GMC there is play with the pedal)
The steering was loose feeling and pulled hard to the right. They truck did have oversize tires so tire pressure could account for that.
I'm just not sure how these trucks are supposed to "feel" while driving. Some input from an owner would really be appreciated. Thanks! I wasn't too impressed with this truck, it just didn't feel right to me...the condition was beyond amazing except the interior...I'm not going to buy that one in particular though.
There may be some thing wrong with tranny if its shifting hard ( i take it its an automatic tranny) and it may be pulling to one side because of the tire pressure but i don't think it would pull hard because of that, there may be a frozen caliper on the brakes which is making it pull, and my brakes don't have much play either there pretty touchy so i think that's normal.
Shaking the Bush Boss
My brakes arent real touchy, but they work fine. My truck goes pretty straight. The tranny has about 20k on a rebuild, it shifts real firm. As far as the steering feeling loose, could be the drag link and tie rod ends. Just replaced mine, ends and drag link, Made a world of difference. Reach under, and grab the draglink, see if theres any play in it.
I have a friend thats got a 96 f350 dually, 2wd for sale. Its clean, less than 150,000 on her. Search in the classifieds or P.M. me, if interested. I've got a few pics of it.
Looking for a 4x4 only but thanks anyway.
The steering just felt sloppy, and would tug hard to the right all the time. I felt like I was fighting it through the entire test drive. I guess the brakes were normal then? There is another for sale at a dealer about 90 miles away from me. I might go check it out, they've listed it a couple times in the auto trader and it keeps going down in price. They want $7995 (started at $9995), it has 210K miles on it, pretty high but I guess if it was maintained there shouldn't be much to worry about :dunno: I could probably lowball on the price maybe walk out the door for $6500
I'm specifically looking to get a 96 or 97 crew cab short box, with the red interior...yeaah I'm specific...
That isn't necessarily true.
If you put a Sonnax Accumulator Valve & Tricumulator Spring, it will shift hard also.
Just because it is shifting hard, doesn't mean there is anything wrong with it. :thumb:
tranny had no modifications, every gear felt like a hard clunk...you could really feel & hear it.
Discussion Starter · #8 ·
That you or they know of, was this a Dealer? or the 1st owner?
Again, Hard shifting doesn't mean it is on the way out.
Is it slipping?:confused:
Second owner however he knew the vehicle inside and out..it's a 94 basically turned into a 1997 XLT model. The motor and transmission were unmodified.
It didn't slip at all. Just changed gears very hard (its automatic by the way). I gave it a bit of full throttle and the downshift from 3rd to 2nd was very hard. The whole truck jolted. Upshifts were the same.
what exactly do you mean by its a 94 basically turned into a 97?
is it a 94 or 94.5 because if its a 94 i don't think it is a powerstroke i think powerstroke engines were from 94.5 and up. and no hard firm shifts don't mean the tranny is broken, but the way hes been describing it, it doesn't seem to be normal.
my brakes have some play in them and work great, my tranny also shifts kinda hard and it was rebiuld 1,000 miles ago. my steering is tight and it goes down the road straight as possible. These trucks are 11-14 years old so things will vary from truck to truck depending on what its life has been like.
Discussion Starter · #13 ·
X2!!!! :dunno:
If it is a 94 with a Auto, then it is NOT a Power Stroke! :doh:
I should have explained before, the motor is swapped from a 97, it is the 7.3 turbo diesel powerstroke. The truck was actually a base model 1994 F350. It had been turned into a 1997 XLT model, everything from the motor, to doors even tilt steering...regardless I'm not going to get it since I feel uneasy about it.
Thanks for the input so far. I know they're all going to have a different feel depending on their life, I'm just not sure what to expect driving wise from these fords. Like I said I'm driving a 1/2 ton 2wd GMC right now so it's a big difference between that and the ford.
Here is one i've found fairly close to me. What do you guys think? 338,000kms = 210,023 miles. The price as of now is $7995. My plans are to get one of these and baby the crap out of it, suspension lift, new paint, every nook and cranny clean...yeah I know they're supposed to be work trucks, I just like having a clean rig...and a big a$$ truck!
1997 Ford F250 for sale in Paris, Ontario Used Cars - Carpages.ca
:woot:
1 - 13 of 13 Posts
