Look sometimes it's difficult finding the info you're looking for using the search function.
I have a Scangauge and when I'm driving to work, 45 minute drive, air temp 65 or so, going 70-75, I often get a coolant temp of like 186-188. I'll get a delta between 5-13. When it does hit 190 the delta seems to be 5-9 range.
I thought I read that the delta should be taken after hitting 190 and only after hitting that point.
It's somewhat hard to get the truck up to 190 at times. Weird?:dunno: Or do others have this same problem.
