good explanation ..and nice pic. I expected a hpop to be much different inside.
so what broke on that pump?
I just say the 15° is a whimpy lowout put version of a 17° pump.
there are other things to look at though.
there is joey's modded 17° pump..basically a pimped up stocker but flows better
but not as much as pulse. But also low $
I did some tests on dieselsite 's pulse unit. It made a very big difference. ok not full blown chip difference , kinda like adding 20tow tune feel. much more consistant smooth pull, 50~70 acceleration when up. mpg gains etc.
then there are the high dollar twins . the diy stealth which looks like the pic above.
and may not be even made anymore, with new stealth comming.
and joeys prebuilt twins....
big oil, and even bigger oil makes a difference you can feel. especially from an early 99
I usually just do 15* and 17* cause it is quick
but the "degree symbol " ° " is hold down alt ,type 0176 on the number pad release.
