1 - 2 of 2 Posts
Question... if I get the new Spartan TCM and install it, will it need to be swapped out if I need to take it back to the dealer for work???? Also where is it located, I think it is under the truck and about under the drivers seat, is this correct???
Thanks in advance
Yes, you would have to swap back to the stock TCM. It only works with the tunes Matt makes for it. Anytime you have to go back to stock would have to be with the stock TCM. And yes. It is located on top of the frame rail underneath the middle of the cab.
1 - 2 of 2 Posts
