Getting a TBC fault only in freezing Temps, happened last winter as well.
Any ideas where to start or why?
If corrosion clean it any thing to spray or lube it up with? ThanksCheck your trailer connector on the truck for moisture/corrosion. If nothing found, you've probably got a cold solder joint inside the TBC that's broken. You have 3 choices:
1. Pull TBC and inspect all cold solder joints - repair if anything found
2. Order a new one from Ford ($PENDY!)
3. Send yours in for repair 2005 - 2007 Ford Super Duty Trailer Brake Controller Repair
-jokester
Good advice, except I certainly wouldn't advise brake kleen, that can soften and damage insulation. Use WD40, it's low viscosity, water displacing, and lubricating properties can do a reasonable job at cleaning electrical components without damage.If it were me, I'd test your connector pins on the truck side first before disassembling. You might not even need to go that far as to clean it.
If you do decide to clean everything, disconnect both batteries & take your connector apart as much as you can to get to the wires & pins. Make sure to clean off all wires & pins with a small wire brush or brass brush, some brake kleen, and blow dry with air before reassembling and hooking up the batteries again. I'd also use a dab of dielectric grease to keep out moisture.
Others probably have better ideas how to clean it though. This is just the way I would do it with what little knowledge I have.
-jokester
Wait...you clean the insulation?Good advice, except I certainly wouldn't advise brake kleen, that can soften and damage insulation. Use WD40, it's low viscosity, water displacing, and lubricating properties can do a reasonable job at cleaning electrical components without damage.
