1 - 2 of 2 Posts
Hi there. I have a 2015 f350 with the tailgate step. The left and right caps are broken. So, I plan to replace all three. I cannot find any detail on how to remove the center cap. Can anyone provide any guidance? Thanks in advance.
If its anything like my 2013, when you have the gate down, pull the step open just far enough to look underside -along the far right edge.
There, is a plastic clip molded into the cap's underside holding the bent rod that is a hinge pin that runs the full length of the cap.
Pop the rod out of the clip and pull the rod to the passenger-side direction and out to release the cap.
k
1 - 2 of 2 Posts
