1 - 2 of 2 Posts
2000 F350 JUST HAD THE T/C REPLACED WITH A BILLIT T/C AND THE LOUD NOISE IS STILL THERE NOW WE ARE PULLING IT BACK OUT TO CHECK THE FLYWHEEL I HOPE THAT IS WHAT IT IS AND NOT THE MOTOR. YOU CAN GIVE THE TRUCK SOME FUEL AND IT GOES AWAY AND WHEN YOU GO BACK TO AN IDLE IT COMES BACK.
Discussion Starter · #2 ·
THE SHOP CALLED AND IT IS THE FLYWHEEL SO I SUGEST TO CHECK THE FLYWHEEL BEFORE YOU BY A NEW T/C.
1 - 2 of 2 Posts
